If a cable type is defined in NEK TS 606. Is it then given that that cable can be used in a cable transit? ie MCT, Roxtec, Hawke etc ? If not. What specs does a cable need to have to be able to be used in a cable transit? I assume armour is relevant for instance...
Løst
