Kabelføring
Spurt 7:44 - 13.12.2008 av El offshore|Siste svar 8:32 - 9.3.2009 av Forumleder
El offshore
Lurer på hvor det står at du ikke har lov til å legge ""blåkabel"" og instrumentkabel på samme kabelstige.
Har en diskusjon og noen sa at det ikke var lov, jeg mener at i spec står at det er 3 hovedføringsveier ombord, høyspent, lavspent og instrument.
Svar (4)
Norsok E001
Postet 10:43 - 13.12.2008
NORSOK standard E-001 Edition 5, July 2007
NORSOK standard Page 40 of 112
For equipment supplied with flying leads, suppliers standard cables are accepted. It shall be as short as
possible and with mechanical protection.
9.2.2 Cable segregation
The cable network shall be separated into the following systems:
¾ System 1 High voltage systems (above 1000 V);
¾ System 2 Low voltage power supply and control cables for electrical systems (1000 V and below);
¾ System 3 Instrumentation and telecommunication systems.
Cable ladders installed horizontally shall have sufficient space to facilitate cable pulling and
cleating/strapping. It shall be minimum 300 mm free space between top of one ladder edge to bottom of next
ladder edge, and from top ladder edge to roof.
Instrumentation and telecommunication cables may be routed on system 2 cable support systems when
minimum 300 mm distance between the individual systems are kept.
System 2 and system 3 cables can be installed on same field tray from branch to single equipment when this
is not in conflict with the type of signals in the cable.
Crossing at right angels is acceptable without further segregation.
Considerations shall be taken during installations of cables entering and leaving field type of equipment like
smaller packages, minor modules, crane pedestals etc. related to segregations as listed above.
Non-IS and IS instrument cables should be routed on the same cable ladders/trays. If routed on same
ladder/tray, the IS and non-IS cables, which contain both armour and screen can be tied together in same
bundle.
De siste 10-15 årene, så er alle nye plattformer bygget med kun en type system 3 kabelgater... Da blir alle instrumentkabler, is og ikke is lagt isammen på disse kabelgatene.. Derfor må også alle disse kablene ha både armering og skjerm..
El offshore
Postet 17:06 - 13.12.2008
Var det jeg trodde.
Takk for hjelpen
Postet 8:48 - 30.12.2008
Beklager litt sen tilbakemelding. Har vært veldig mye på farten. Ser at du har fått et presist og godt svar på en av trådene, og dermed er vel saken ute av verden, men jeg kan jo supplere med IEC 61892 sier det samme som Norsok. Poenget her er at man har med seg armering og skjerm. Man kan faktisk også forlegge uskjermet ""blåkabel"" og instrumentkabel på samme gate, men da kommer det krav til avstand.
Postet 8:32 - 9.3.2009
Bare for å få denne saken ut av verden - det står INGEN steder at du ikke kan legge blåkabel på samme swtige som annen kabel under forutsetning av at kablene har tillegsbeskyttende kappe, ref IEC 61892-7, punkt 7.9.7
